Old 04-28-2009, 08:45 AM   #1
jjanari
The only c-clip I'm aware of is the one that holds the inner cv joint to the axle...is that what you're talking about? If so, you need to pry off the metal end cap to remove the cv boot to get to the c-clip and use c-clip pliers to remove.
Also, not sure what you mean by leaking from the axle..are you talking about cv grease?
in any event, this link may help you:
http://www.pedrosgarage.com/Site%203/Replace%20the%20CVJ%20Boots%20%26%20Half%20Axles.h tml
jjanari is offline   Reply With Quote
