also, I would check your oil level to make sure you're not getting coolant in the oil, though I doubt that's what's happening from you description since you seem to see where all the coolant is going (on your floor!). (I also question the suspect head gasket diagnosis by your mech, but I'm certainly no mechanic). if it were my car, I would try and pinpoint the leak by getting the car up on ramps the next time it happens to see exactly where the coolant is coming from.
