Originally Posted by jayster
the Alarm keeps going off on my boxster
I lock the doors with the fob and roughly 3-5mins the alarm goes off
sometimes when i lock the car with the fob i get the 2 horn beep after - i have checked all compartments are closed etc
The battery is a Varta and been checked and thats fine, theres no water under passenger seat.
its going off at random times in the night - my neighbours must be impressed.
i took it to a local garage and put on a diagnostics machine - it found 9 faults
Heres the results, please if anyone can help im pulling my hairout
1. No central Locking Possible. Central Locking Synchronization. [2F]
2. Left Door Secured but Not Locked. Test Point 13 [0D]
3. No Passenger Compartment Monitoring sensor Faulty [21]
4. No central Locking Possible. Central Locking Synchronization [2E]
5. Interruption of Alarm Output. Voltage Failure during Alarm Output [0B]
6. Alarm System / Central Locking System without Function. Voltage failure at Terminal 30 with Alarm System Active [0A]
7. Central Locking limit position locked not reached. Switch for Central Locking is Faulty [39]
8. Door (s) secured and Terminal 15 on. Check Coding Country Configuration [01]
9. No Central Locking Possible. Drivers Side Release Stuck [2C]
can anyone please help me
thanks
Unfortunately I can't help with your 9 faults, but if you want to stop annoying the neighbours with your alarm, try clicking your fob twice in quick sucession when locking your car, you should hear a single "horn beep" this shows that the car is locked but the alarm is disabled, that should give you a bit of time to sort it out .
Chris.
