Old 04-22-2009, 11:19 AM   #3
heyjae
There are several brands of LSD. Quaife is popular. I believe Cusco and Kaaz make them for Boxsters and some custom shops build them as well. They are around $1300-2000 if I recall correctly. They will help with traction accelerating out of corners and stability braking into corners. Frankly, in my opinion, I would not get one unless you are tracking fairly regularly. It is relatively expensive and helps in very specific scenarios and won't make a difference 99% of the time on street, so the cost/benefit doesn't add up for me for the street. Plus, if you NEED an LSD on the street, then you should probably be on the track.
2000 Boxster S
http://www.slipangle.com/images/ACSpeed_sig.jpg
heyjae is offline   Reply With Quote
