Front will be fine; you may be a little tight on the rear inside, but it will depend on tire brand and width. If so, a small spacer will put you in business. Generally, an offset of 47 is desirable in the rear.
I have 18X10s et47 on the rear of my '02 S ...the only trouble I had was rubbing on the parking brake cable, which needed to be tied back.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
