Old 04-17-2009, 12:14 PM   #1
Christian H
Christian H's Avatar
Originally Posted by cwm50
The plate lights on my 2000 Boxster S are not working and it's not the fuse or the bulbs. Anyone have any thoughts to fix the problem??? Thanks!!
I had the same problem recently,mine turned out to be the sping clips that hold the bulb in place,the clips slide into grooves either side of the lens,in my case the plastic had degraded making the clips loose on the bulb and stopping continuity of the circuit.
Worth a look!
Chris.
Christian H is offline   Reply With Quote
