Old 04-16-2009, 07:33 AM   #14
Topless
Track rat
Topless's Avatar
Originally Posted by legume
The car is still with Vancouver West, they're going to keep it overnight but they think they've found the problem. Was told that the PCV breather filter assembly is cracked and that's where the oil is coming from.
BTW, I checked my invoice from last week and it turns out that Alfred did list the error codes: DTC 1128 and DTC 1130.
Will keep you posted.
Looks like a failed AOS causing your car to run lean. Have them replace the AOS if it is visually cracked or leaking. The MAF and O2 sensors were probably fine all along and they just missed the AOS problem. $810 oops.
