Old 04-13-2009, 03:47 PM   #2
Travis
Send a message via AIM to Travis
Originally Posted by 986_Ron
Travis, thank you! Just the kind of info I was looking for. Looks like my local Sears has one.
Did you re-use the squeeze clamps on the new res or go with the screw type that j.fro recommends?
I actually re-used my clamps as they were in great shape and really could not see it being easier to try and use a screwdriver to get it off if there were to be a next time.
Also one more tip for you, the three hose connections from the trunk side to the reservoir - make sure to mark them as to where they go or layout as removed, diameter of the inside of hose are different.
Once all clamps off, hoses disconnected and screws are out you will have to pull HARD to remove (make sure all are disconnected)
Travis is offline   Reply With Quote
