Old 04-07-2009, 04:29 PM   #3
Lil bastard
Lil bastard's Avatar
Listening for a click doesn't necessarily indicate a relay is OK, some relays are solid state and so do not click at all.
To do a proper test, you really need a DMM (digital multi-meter), 2 small jumper wires and at least a 9-volt battery, or you can use the car battery (12V). Remove relay before testing.
First, using the DMM set to ohms, check resistance test between terminals 85 and 86. Resistance value (ohms) should be 75 15 ohms for resistor equipped relays.
Next, connect the DMM between terminals number 87A and 30. Continuity should be present at this time - meter will read 0.
Now, connect the meter between terminals number 87 and 30. Continuity should not be present at this time - meter will read infinity (sign).
Now use a set of jumper wires (16 gauge or smaller). Connect one jumper wire between terminal number 85 (on the relay) to the ground side (-) of a 9-12 Volt power source - the battery or 9-volt, and attach the other jumper wire to the positive side (+) of the same power source. Do not connect this jumper wire to relay at this time.
CAUTION: Do not allow the DMM to contact terminals 85 or 86 during these tests while it is in the resistance (Ohms) mode - you'll damage it.
Then, attach the other jumper wire (9-12V +) to terminal number 86. This will activate the relay. Continuity should now be present between terminals number 87 and 30 - (meter reads 0). Continuity should not be present between terminals number 87A and 30 - (meter reads infinity).
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
