Old 04-03-2009, 07:09 AM   #11
Jaxonalden
Jaxonalden's Avatar
[QUOTE=jmatta
I'm seriously considering installing the low temp t-stat this spring, so I'll likely find out what works the best.[/QUOTE]
Lower than 180 degrees? Why is that? To fool the ECU into thinking the engine is still cold so fuel is enriched trying to get the engine up to temp? I would think the thermostat is set for one purpose, proper sealing. The engines dissimilar metal parts expand at different rates and in that expansion engineers have determined that 180 degrees (coolant temp) is the optimum temp for the cylinders, pistons and rings to seal properly. This minimizes blow-by, contamination of the oil and excessive wear on the rings from the extra fuel “washing” the oil off of the cylinder walls.
