Old 04-02-2009, 04:04 PM   #2
Lil bastard
Lil bastard's Avatar
Originally Posted by eightsandaces
You Da Man LB, I knew you would slide by with the 411. Regarding the refill, is there a procedure for bleeding requiring the manipulation of the filler inlet? I could have sworn I read in the Bentley book that a specific operation is carried out during refill.
You don't exactly manipulate the inlet. If you remove the oil and coolant caps (and dipstick if you got em), you can then lift the black plastic cover/escucheon under them by carefully prying it up. Underneath you'll find the coolant bleed valve controlled by a 'D' ring. You lift the ring to open the valve and then run the engine (filled w/ coolant of course) and vary the rpms up to 2500 for 5 or so minutes and any air in the system will migrate to the open bleed valve - be sure to have some towels in the trunk in case any coolant overflows. It is sometimes necessary to repeat this procedure after several days.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
