			I would absolutely stay away from anything that involves high pressure.  You can clean the engine and engine compartment with various engine cleaning solutions, though you'd be very wise to find a way to keep the chemicals and the released dirt and grime off the rest of the car.  Cover the alternator.  Use a brush and use as little chemical as possible.  Then rinse with low pressure water and do not direct the water at anything electrical.
				Boxster S
