Originally Posted by rick3000
I installed OEM rear speakers over the summer and they made an improvement for me. If you want to upgrade the speakers any 3.5" speaker should fit, and you might be able to fit dedicated tweeters in there, I know a few people have.
Have you tried adjusting the balance? If you can't hear anything from them, turn up the sound from them, I had to mess around with mine, until they filled in the cabin nicely.
I haven't really messed around with the fading except to make sure the rears were working. I'll try that and see if it makes a difference. I just figured that the 996 amp would be pushing the same wattage to all speakers, therefore reducing the need to fade as you have to when the rears are wired directly to the headunit.
I have swapped out my dash speakers with Infinitys, maybe they are overshadowing the rears. I'm going to swap one side of the rear with some 2 ways and compare, I'll report on the difference.
