Exhaust was lined up with the dot in centre of bright link. Intake was 1/2 link out.
Removed intake camshaft and camshaft tensioner and found the camshaft slide on the bottom of the tensioner only had about 1/2 left.
Also there is a rub mark on the tensioner from camshaft chain rubbing it. I believe camshaft chain got caught and skipped 1/2 link. That would probably throw the timing for the camshaft position sensor off. This could also cause my rough idle, and missfire codes.
