Originally Posted by bmussatti
None of these options remove the moisture from the air. This would be an advantage.
Add a air inline filter and lubricator if your concerned about water. For anything being used around the house, this may be overkill. I just add a couple drops of oil to the air tools. And open the bottom of the air tank every now and then to drain the water out (obviously when its not pressurized).
