			I would recommend going to AutoZone for a battery... and save about $100.
Before changing the battery, starting pulling fuses.  My car had the horn stuck (steering wheel air bag) and both horns are bad, so I didn't know it (never tested the horns when I bought the car).  When I pull the air bag out, I heard a "click", push in "click".  So my relay was held closed by the horn, causing the battery to drain.
I would also have a shop check to see what the alternator is putting out.  Is a simple check to verify that the battery is being charged.  I would do that first, before changing batteries.
				My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
