Old 03-25-2009, 05:38 AM   #11
boxster1
simple
It turns out this is a very easy adjustment to make. For Litronic lamps all you need is a 5mm Allen wrench. Open your front trunk and unscrew the plastic knob on the side of the wall next to the lamp you wish to adjust. Peel back the wall and follow the diagram that Travis linked to us below.
While it is easy to adjust these lamps, it appears that aiming them correctly will take a lot of trial and error unless you have level ground with a wall you can mark.
boxster1 is offline   Reply With Quote
