Old 04-24-2005, 09:01 PM   #1
Morelli
Do a compression test. If the smoke is bluish, and comes in when the engine is under load (heavy acceleration, deceleration by downshifting), you could have burnt up the piston rings. A compression test should be able to tell you which one if that is the case.
www.matt3t4.com
Morelli is offline   Reply With Quote
