Old 03-22-2009, 10:27 PM   #12
sd_boxster
I got all of the stuff from Amazon except the antenna adapters (Crutchfield) and the Sirius box (Best Buy).
This was by far the easiest stereo install I've ever done - since I was using the RCA preouts, NONE of the speaker wires got connected. Wiring for the JVC includes a constant +, a switched +, and a ground. I didn't even run a wire for illumination, since the JVC unit allows you to program the dimmer to operate by time of day (neat feature).
This install is definitely not over your head - ESPECIALLY if you don't do the Sirius. The hardest part was finding room for the three supporting components (two boxes for Sirius and the RF modulator), and I admit that there is a rat's nest of wire under the console I ought to tidy up sometime soon.
sd_boxster is offline   Reply With Quote
