Old 03-20-2009, 06:37 AM   #8
Christian H
Christian H's Avatar
Originally Posted by chaudanova
Hi, would you be able to post some pictures please? I'm interested in doing this mod!
Could not find any pictures from when I changed the trims over, but I took these pictures today to give you a good idea of how to tackle the mod,there may be slight differences between left and right hand drive cars and maybe the age of car but I would assume they should all be very similar.
These are the silver trims that I removed,they show the screw holes and clips on the rear
Firstly remove the foam cover under the dash,this is held with two plastic screws
Next pull the air vent tube down(squeezing it together at the same time helps)
This will allow access to the torx screws
The weapons of choice,flexy driver and hand light.
Seven torx screws in total(size T10) on the passenger trim,the silver item in the picture is the air bag(there are two screws on each of the drivers side trims)
Then its just a case of undoing all the screws,as ddb stated take your time and take breaks if you get fustrated its well worth it.
The drivers side is the same set up with two screws in each,if you need help send me a pm.
Christian H is offline   Reply With Quote
