Old 03-18-2009, 09:54 PM   #1
sb01box
01 boxster Engine SMOKE
88K miles, 4 months pass the 2yr used Porsche warranty.
car has been trouble free except left rear bearing. no oil leak, no oil consumption. in fact, this is the first time i have not changed oil at 7500 mile, at 13000 miles since last oil change, dipstick and sensor indicator both read 100% oil.
came back from work, after dinner plan to go to local tech store.
Started the car. funny grunt. turn ignition key again and the car started.
little heavier than normal white puff .. but when i started to drive down the street, more smoke, then none. got on the freeway and all hell broke lose. white smoke all over . got off the freeway and drove the car back.. about 1 mile total.
The smoke engulfed the street in front of my home as though my house was on fire.
at home, couple of engine on off and i noticed oil leak just behind the driver's seat. looking from the back of the car, it looks like at the left front corner of the engine. top of the engine and basically everywhere that i can see with flashlight looks dry.
looked at the dip stick and the sensor indicator, it seems that the car drank all of its oil in matter of couple of minutes. no cel or indicator of problem. coolant temp is normal
no oil in the coolant, no over pressure at the oil or the coolant filler cap.
smoke is not caused by antifreeze- it does not have the sweet smell. also the reservoir level is normal.
my optimistic assessment is that the driver's side return oil pump died and that side filled with oil and went into the intake of the engine.
other than the smoke and hesitation at times due to oil soaked plug, the engine runs and sounds normal.
will have the local dealer inspect it asap.
any comments, thoughts, past experience?
assistance is greatly received.
SB01box
sb01box is offline   Reply With Quote
