Old 03-17-2009, 03:30 PM   #1
crios
Hi Sean,
Here's some good step-by-step intructions if you wanted to pull your brakes and paint them with a spray can versus a brush.
http://www.pedrosgarage.com/Site%203/Paint%20the%20Calipers.html
I did mines with G2 Brush, and would suggest doing this way as well. It was very very easy and G2 can withstand 900 degrees, while the spary is only rated to 450.
If I did again, I would buy a better brush at a craft store than the one that comes with it.
The decals you should get are 3 inch ones.
I also brushed all areas as seen here:
-Cesar
03' 986 Midnight Blue Metallic
_____________________________________________
Gemballa Lowering Springs | 18” Carrera Light Wheels | Painted Calipers
14/18 H&R Spacers | Aero Wing & Rockers | Powder Coated Exhaust
Creator of CRIOS exhaust mod | De-Snorkeled | De-Ambered
Light Weight Flywheel | Tinted Windows and Windscreen
Painted Bumperettes | 550 Spyder Grille Kit
http://lh5.ggpht.com/_9sTq_sN1KDw/Si...2009%20055.jpg
crios is offline   Reply With Quote
