Old 03-15-2009, 10:17 PM   #4
Banana S
Originally Posted by blinkfan
...So I purchased a Fog system which shoots 50psi into my air filter... I checked my air fuel ratio by checking the OBD2 data with a Snap On Modis.... 15 to 1 was the leanest the engine ran which is good...
In a word, no.
15 to 1 A/F ratio while spraying = KABOOM.
So either you're talking about your A/F ratio when you're OFF the spray, which would be about right (stoich is 14.7 to 1) or you are spraying at part throttle (which also = KABOOM), or you are running WAAAAAAAAY lean on the spray (which will eventually = KABOOM).
Let's see some pics of this setup. Because a Fogger system is a direct-port system, which would attach AFTER your MAF, not before it. Color me skeptical.
Banana S is offline   Reply With Quote
