Old 03-13-2009, 09:58 AM   #2
pschaub
What I used for my install
Hey TorpedoZone,
http://industryfigure.com/berkeley/Porsche/Accessories/valentine.htm
This is the site I followed to hard-wire my V1 in my '98 986 (...sorry not a 987) It has very nice step by step images.
I did not run my cord all the way around the outside of the car as shown; I simply ran the cord up along the drivers side of the center console, tucking it under the cluster gauges, allowing enough left over to connect to the V1 when mounted on the windshield (not too low, but high enough to be able to pick up signals from behind).
When / if I unplug V1 the wire wraps nicely around the top side of the gauges, keeping it almost out of site. Also , my concealed display is attached to the center console as shown in the examples, which makes it very easy to mute with out getting in the way of the steering wheel, or much arm movement if my hand is already on the shift knob. I"ll try to get some pictures up later this weekend.
You may need to check the wiring colors in the middle console (or other area you select for the power) to make sure that you are connecting to the right one. I found it easier to be on the passengers side when connecting the harness to the unused 'cell phone' power supply in the center console.
Hope this helps.
Peter
Last edited by pschaub; 03-13-2009 at 10:20 AM. Reason: content correction / typos...
pschaub is offline   Reply With Quote
