Originally Posted by jjanari
I also flushed and filled the coolant. I suspect the coolant was original (is the orig green?); either way, the coolant that i drained looked pretty clean. it's suppose to be lifetime, but that's probably not realistic. I refilled with havoline extended life.
I have never looked into a coolant flush on my '03 with ~40k. I was under the impression that the only coolant we could use was some super special fluid that for $45 a gallon must be made from the milk of a virgin yak.
What is the story here? Can we use conventional coolant in the 9x6 as long as the whole system is flushed?
