Thread: Zeintop
Old 03-06-2009, 01:25 AM   #2
Chippy
Originally Posted by threpwood
Got the manual from zeintec. Luckily it doesn't look so hard. The only problem is probably the wiring through the firewall since I've never fiddle with the boxs wiring. Thanks!
It's really quite easy - easy than the manual makes it look, but here's a couple of tips:-
1) The cable is a h shape - the end with the two connectors goes closest to the back of the car and the single connector end goes to the demister plug.
2) When you fit the hatch, remove the hinges from the roof (which they come attached too) and attach them to the hatch first instead - you'll find it much easier to attach it that way, rather than the other way round.
Chippy is offline   Reply With Quote
