Old 03-01-2009, 02:46 PM   #6
HB.
Originally Posted by Boxtaboy
Yep, as Maurice said, I had what felt like grinding or shudder in the left rear axle when making turns. In my case, it was on right hand turns under moderate power (usually in 2nd gear). There was not really a clunking sound though.
Turned out my motor mount was torn, and allowed the engine to shift enough during cornering to upset the driveline geometry. I thought at first it was a driveline or suspension issue, but the installation of the new motor mount cured the problem. and I can't recreate the noise anymore.
How much did it cost for the repair? Did you do the work or a mechanic?
HB. is offline   Reply With Quote
