Originally Posted by 986Roadster
Hey,
I have bought coilovers and strut bars for my boxster. I am having them installed next month. I need help, I'm not sure if I need anything more. My mechanic say's that I don't. I do not plan to track my car. I just want a tight suspension and to improve my handling. I always liked driving lowered cars.
2002 Base Boxster
H&R coilovers - thinking to drop it 2inches.
Schenell Front and Rear Strut bars.
19 inch rims and the rear rim is 10.5 width
Do I need any other parts? Rear toe bars - I don't know anything about these, but have read alot here on the board. But are these only for the track. Do I really need these rear bars for daily driving.
Need help as you can see!
Sounds like a good setup... You may want to consider front and rear sway bars, and a rear lower brace as well.
If you plan to go 2" lower, like you mentioned, you'll most likely be needing a set of rear adjustable toe arms in order to get your alignment for toe back to proper spec. PM me, I have a new set...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
