Old 02-24-2009, 10:41 AM   #3
ekam
Originally Posted by tholyoak
The 986/996 use a potentiometer that is separate from the pedal assembly while the 997/987 cars use a lighter setup where the potentiometer is integrated into the pedal assembly. So even if you had the $$ to throw away, the connectors on the two setups are different so the 987/997 sprintbooster won't work on the 9x6 cars.
-Todd
Good to know. Thanks for the info.
