Thread: Coolant leak
Old 02-20-2009, 04:09 PM   #3
tommy986
Schatten-Baum-Mechaniker
Originally Posted by Viper5
Did you have someone tell you that or were you able to figure that out on your own? If so, then how? And how much did it cost?
How is it the water pump if I didn't turn the car on (not giving power to pump) and it's still leaking?
After reading in this forum and others about water pump failures, I figured it out on my own. I'm not a mechanic, I just play one on weekends. :-)
If I remember correctly, the failure mode is that the shaft wears, so it's seems possible that a system under pressure could still push water down the shaft without it spinning. The only other part in that area, dealing with water, is the thermostat, which is off to the side from where you took that picture. I replaced it at the same time since I was draining the system anyway.
If i were doing it again, I would get one of those 160 degree thermostats from Flat6innovations.
I sourced all my parts from Sunset Imports since they had the best prices and good service too.
Tommy
Tommy
2000 Boxster S
1973 914
tommy986 is offline   Reply With Quote
