Old 02-18-2009, 11:13 PM   #10
Mike_Yi
Originally Posted by mmuller
I bought 2 Recaro SPG's (non XL). They came with the stock Recaro sliders and adjustable side mounts. I then took the BK R-9040 Seat track adapter kit to mount the sliders to the floor and the mounts to the sliders. I mounted the seats as low in the brakets as they could go.
By doing this I gained around 3 inches of seat drop. Where I used to look through the top of the windshield, I now look through the middle to lower half of the windshield.
That's pretty much what I've decided to go with Mmuller. I sat in a Boxster with Pole Position seats + sliders and had much more headroom. If you look at the BK brackets, they have more adjustment holes for reclining more too. I've been told that the BK brackets will let you lower the seat even further, though I have come to trust those people less now. I've also read (in only 1 place) that the Sparco slider is actually lower than the Recaro slider. BK's brackets work with the Sparco slider. I have to call BK tomorrow to ask them about that. I'll let you know what I find out.
By any chance do you still have the stock seat around? If so, could you do what I did (first measurement I described) to measure to see just how many inches lower the SPG is from the stock seat? It would require you to pull the Recaro seat to get a really accurate measure, but it would be great info for people like us.
Originally Posted by johnsimion
Is the vertical adjustment of the stock seat limited by the electronic whatzit that's under the driver's seat? If so, can the whatzit be relocated to under the passenger's seat? I am just looking for an inch or two additional clearance from the rollbar on the driver's side (my passenger is 5' tall and height isn't an issue). I can't see investing $1500 to $2000 for a couple of seats for a 10 year old car.
Not that I can tell John. I looked at the stock seat pretty carefully. I was trying to figure out if there is a way I could modify it to lower it. It could be done. There is a piece of metal between the seat frame and the sliders. In the front it could save you about 3/4" to an inch. The problem is that in the back it would only save about 1/4" unless you actually modified the seat frame. Most of the space up front, I think, is for the shock that pushes the seat up when you are raising the seat. Us tall people don't care about that, so that could come out. It wouldn't help in the back though.
Mike_Yi is offline   Reply With Quote
