Hey I never heard of that Delvac product... Is that really the best fluid for the 986 6 speed? I was going to replace mine with Redline 75W90... My car has only 12,000 miles on it but it's a 2001 so I think I should replace it. Thoughts?
Also, I made my own pump when I replaced the fluid on my Z.
I took the cap on one of the quart bottles and cut 2 small holes in it. I inserted 2 tubes into the cap, one longer than the other. The one that is shorter you connect to your compressor and set it to 5 PSI. the other tube goes into the trans fill hole. Then push some air into the one line and it will push the fluid out of the bottle. IT works nice and you can reuse the cap on the other bottles.
-Steve
2001 Boxster S
Desnorkled
Pioneer Avic D3
JL Audio 6.5 inch subs (in the door)
Pyramid 4 channel amp
