Old 02-17-2009, 06:52 PM   #16
Lucky
Viper,
Your pic #1 shows the fill plug. Pic #3 is the drain plug. Both are 10mm allen, I believe.
The manual you have shows pics of a 5 speed tranny, which is part of the confusion.
When filling slip the hose from your pump into the fill hole and use a piece of tape around that squared-off support bracket you see in your pic to hold the hose in. Pump away until a bit of fluid drips back out... when that happens it's full.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
