Old 02-17-2009, 01:58 PM   #1
Mike_Yi
Originally Posted by Jaxonalden
How's the back angle? I'm 6' and I find that I'll sacrifice leg room and slide the seat forward and then lay the back down a little for a more comfortable ride. I'd hate to buy a set of seats and find I can't stand the fixed position. I'll stick with my stock seats, thanks for the heads-up.
That's a hard question to answer. I can't put a number on it because, like the stock seat, the GT3 seat back is not a straight line. I have always sat with my back at a pretty large angle too because it usually helps with the head room. However, I do find the GT3 seat to be very comfortable. It does feel very upright, but it's not so upright that it is uncomfortable.
To try to give you an idea of the seat back angle, I found a way to measure it. I set the stock seat as described above. I looked at the seat back for a flat surface, and the only part that was flat was the back side of the head support. I put a protractor on that part with the flat side against the seat. I then put a small level on the arm of the protractor. The angle it gave me was 96 degrees. If you imagine the protractor as a backward D, the arm of the protractor is pointing down at 6 degrees. That means that the top of the headrest is leaning slightly toward the front of the car. That seat position is, as far as I can tell, the same seat back position as the GT3 seat. They feel the same, or very close to it.
Mike_Yi is offline   Reply With Quote
