Old 02-16-2009, 02:35 PM   #1
Lucky
Viper,
The fill plug is near the rear end of the tranny on the driver's side. And if memory serves, an S tranny is supposed to take 3L of fluid (so 3 quarts will be a bit low).
As far as getting the plugs out goes, they shouldn't be so tight that you need to use an impact wrench. Just use your longest ratchet and make sure you are turning the correct direction!
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
