Old 02-16-2009, 06:36 AM   #1
ppbon
ppbon's Avatar
Originally Posted by Viper5
I will go out and get some jack stands. Is there another place to put the transmission fluid other than the oil fill plug because I don't see how to replace the fluid in the hole from underneath. Usually you put stuff on the top.
I use a small manual pump to fill the tranny.
To get the exact amount I made a mark with a hacksaw on an allen wrench 11mm below the bend. This way I insert the small end and rotate it inside he tranny and like a dipstick it will show you the fluid level.
As it's been said, don't use ramps for this procedure, use 4 jackstands instead.
The reason is that if you remove the diagonal braces and the aluminum skidplate fro the car while it sits on the suspension (loading the suspension) the alignment will be out of speck and you may not even be able to re-install the parts.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
