Originally Posted by eddison
I also have the same problem just last week, thanks for part #, but can it be a DIY?...does anybody have a link how to replace it?
thanks in advance
Yup it's a diy. Just makesure u have strong wire cutters so u can cut the hard plastic line, there's a clamp that is impossible to remove without taking off the plenum. Also ull need pliers to remove the clamp on the rubber hose from the sensor. And a flash light to look under the drivers side of the firewall near the engine to pull the already cut plastic hose out from under neath the car. Then route the new sensor under the plenum from up top and then once it's inplace, tiewrap the hard plastic hose from the new sensor to the old clamp that held the old sensors hard line. That's pretty much it.
