Old 02-11-2009, 07:35 PM   #5
Kirk
Originally Posted by j.fro
Then, you will need a hub puller to press the splined end from the hub.
I'm more barbaric. I've found that a hammer with some gentle persuasion works as well.
For the axle nut I used a breaker bar and about a 6' long torque multiplier (cheater bar). That is certainly one tough nut!
I think it looks like this is a case where YMMV (your mileage may vary). I'd take the hub nut off, take the wheel off, disconnect the axle from the transmission, jack/raise the hub up, and then see what kind of angle you can get on the thing and what's in the way. You can then either drop the lower stress plate or the cats depending on what's necessary in your case. But yeah, definitely don't go busting those ball joints, as that's definitely not necessary.
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
