Old 02-11-2009, 04:33 PM   #2
Kirk
I'd take it to a track day or two stock and see how you like it before dumping $5K into it. Plus that way you can kind of calibrate your mind for what the car is like stock and use that as a benchmark for comparing future improvements to.
For $5K you can do a lot:
Coilovers
Front and rear sway bars
Extra set of wheels with sticky tires
I'd personally go for something like this:
Bilstein PSS9 or KW V3 coilovers - $1,800
GT3 front sway bar with end links - $450
Tarret rear sway bar with end links - $425
Wheels - $1,000 used
Tires - $1,200 or so
I think that would be a pretty slick setup for the track, and on the street you can throw on your street wheels/tires and simply adjust the shocks to make it softer.
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
