Old 02-10-2009, 12:54 PM   #3
tholyoak
Originally Posted by nefarious986
would the 987 S clutch work for the 6spd then ?
thanks ahead of time
No personal experience with this, but the 987 6 speed and 986 6 speed share the same flywheel and other parts so I'm pretty sure the 987 6 speed parts will work on the 986. The 986 6 speed and the 996 use the same pressure plate, so there is the potential to mix and match items from the 996/997 to get more clamping force to deal with higher outputs as well.
The only real limitation is in the Boxster/Cayman model range, 5 speed and 6 speed clutch components (outside of the flywheel) cannot be interchanged.
-Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
