Old 04-18-2005, 07:07 PM   #10
Pablito
Subs for Boxster
Under the dash is not a good idea, under that flimsy panel is the entire AC evaporator/blower assembly and it takes pretty much the entire space on the passenger side...Cutting thru the wall behind the seats it's not to hot either, the engine as is runs with very limited clearance and what you have back there is the belts and pulleys, trust me you wouldn't want to mess with that....The best option I am looking at is on the doors, if you remove the factory speakers and enclosures you have a good 4 to 4 1/2 inches of space between the grill and the door inner cover, you can fit 8" subs in each side all you need is a proper enclosure....
Pablito is offline   Reply With Quote
