Thanks Boxtsaboy,
I'll check the clamp. I was thinking it was the baffling inside the muffler because the exhaust tone alternates from sounding very nasally or froggy to sounding deep and smooth like a porsche should sound. I'm envisioning a piece of metal inside that's shifting changing the flow of air through the muffler. But even if it's just the clamp I'll still swap the muffler. It has about 80K miles fewer on it and it has the dual tips. And since I've already swapped out my headers and secondary cats with performance headers and secondary bypass pipes the muffler can be the only culprit left.
Originally Posted by Boxtaboy
An 02 S muffler will fit your 02 base with no issues. The muffer is exactly the same as yours except for the dual tip welded on the end of it.
I used to have a rattle at idle on my muffler too, and at first thought that the muffler had a loose piece inside it, but later traced it to a loose clamp that connects a U-pipe from the cat to the muffler. If I pulled on the u-pipe, I could tell that it was loose and would move. After fixing that, no more rattle.
TimAustinW
http://i226.photobucket.com/albums/d...ignature-1.jpg
02 Seal Grey, NHP Headers w/ Highflow Cats/2ndary Bypass Pipes, smoked side markers/3rd brake light, exterior match interior trim, 986 Lloyds Mats, 986 deck lid emblem, arctic silver intake grills, ipod link, painted calipers, Glass Window Robbins Top with defroster kit, Bose Sound System, Leather lower door panels, Console Lid w embroidered crest; Stainless door sills; Painted Bumperettes; Custom Hood Crest
