Originally Posted by Topless
The water pump is on the front of the motor. Coolant leaks near RR wheel point to the plastic coolant tank and assoc. hoses and clamps. Pull the motor cover or get on a lift and have a good look in that area.
It may well be a hose on the engine side... There is NO moisture in the trunk though, so hopefully the tank is still fine. It is only 5 months old...
