Originally Posted by Boxtaboy
Icedude, I would not replace your AOS or MAF unless you are experiencing problems. If you see that you have a big plume of smoke coming from your tailpipe at startup for a few times in a row, then you may need to change out your AOS. If you don't see any CEL light come on, your MAF is ok. At 58k miles, I have yet to change either on my car.
Oh, and Geoff is correct- starting in 2001 model yr., Porsche offered the insulated liner for the top as standard equipment for the base Boxster. Came with the Boxster S in 2000 as standard. Your dealer didn't add the liner to your car...it came as standard in all 2001 model year Boxsters.
Thanks, my bad on the liner. You guys would know best - which is why I am open to advice/critique. Boxta, the brake discs are a bit rusty, which is common on all cars and I'd like to get new, colored shoes if I go with new rims. how do I shine up the discs. nice rims + rusty and drab discs and shoes = ugliness. Where in NJ are you? I work in Piscataway. Any recommended Porsche mechanics you can recommend?
