Originally Posted by icedude
Thanks Geoff. I meant an insulated liner which is an upgrade to the top and heated seats since this car is a NJ car many dealers sell cars with the winter upgrades. This car isn't under warranty any longer so how much will replacing the AOS and MAF cost? There isn't a spec of anything on the interior. I'm dead serious, this car looks brand new. A little wear on the left edge of the drivers seat which is normal from getting in and out, no chips, cracks, stains. The passenger sid floor mat looks like noone ever sat in that side. 5 nicks on the exterior of the entire car and the rear window is literally perfect. He has a kit of Porsche cleaners in a case in the front trunk and one is the window treatment which he said he's used and he also puts a felt piece between it when the top goes down and folds it. Again, unless the engine blows, this car honestly looks like it's 6 months old.
Icedude, I would not replace your AOS or MAF unless you are experiencing problems. If you see that you have a big plume of smoke coming from your tailpipe at startup for a few times in a row, then you may need to change out your AOS. If you don't see any CEL light come on, your MAF is ok. At 58k miles, I have yet to change either on my car.
Oh, and Geoff is correct- starting in 2001 model yr., Porsche offered the insulated liner for the top as standard equipment for the base Boxster. Came with the Boxster S in 2000 as standard. Your dealer didn't add the liner to your car...it came as standard in all 2001 model year Boxsters.
