Old 01-28-2009, 10:35 AM   #3
renzop
Slow down a bit. Did you read what the factory specs for tire pressure are? Set your tires to those pressures not what Firestone says.
Also since you drove around with 51psi you may have broken a belt in one of the tires. Just go to a tire shop and tell them you suspect that one tire might have a broken belt. See what they say. Stay away from the dealer because as you said they are expensive.
renzop is offline   Reply With Quote
