Old 01-25-2009, 09:14 PM   #1
crios
Originally Posted by CJ_Boxster
Try disconnecting the plug from the Mass Airflow Sensor then try and start the engine, if she starts right up, replace the sensor. Also try to rent the ODBII SCANNER from Autozone and check for pcodes n post them here and we'll help yah out
I had a 99' which did the same thing, cluncked out on my on I-5 in San Diego, 5 hours from home. It would turned over, but would not start, it was the MAF. $600 later, it was fixed by the dealer. Since then I've fixed my own MAF's under $250, a very easy to DIY.
-Cesar
03' 986 Midnight Blue Metallic
_____________________________________________
Gemballa Lowering Springs | 18” Carrera Light Wheels | Painted Calipers
14/18 H&R Spacers | Aero Wing & Rockers | Powder Coated Exhaust
Creator of CRIOS exhaust mod | De-Snorkeled | De-Ambered
Light Weight Flywheel | Tinted Windows and Windscreen
Painted Bumperettes | 550 Spyder Grille Kit
http://lh5.ggpht.com/_9sTq_sN1KDw/Si...2009%20055.jpg
crios is offline   Reply With Quote
