Isn't 51 psi insanely high? If your 3 piece wheels "need" 51, I would be looking at fixing that. Do your 3 piece wheels leak? Is that why you run 51?
I am partial to the broken belt idea. Could the high pressures have broken a belt? You might not see anything abnormal.
Also what about a bad shock? Get under the rear and look for a leaking shock on that side.
