Originally Posted by funkdefino
I just received my Durametric dongle. I can see that I can get a signal reading from the MAF with the software. Is there a way to test the MAF or is there a signal reading that tells me if it is going bad?
I will try re-cleaning and resealing everything tomorrow.
Thanks Lil' Bastard
Here's a graph of a MAF/rpm test I did -- although I have a later model, you should be able to use the chart as a guide. Good luck.
Regards,
paul...
