Old 01-20-2009, 12:40 PM   #3
EE3racing
Guest
Posts: n/a
Originally Posted by pbanders
Like EERacing says, most of us "old timers" learned on cheap cars. Me, it was a Honda Accord. You just need to take it easy and build up your skills if you're starting with your new Porsche.
One of my girlfriends had a VW Bug with a 4-speed manual that I used to drive. The synchros were completely shot so I had to learn how to double-clutch to downshift without grinding. The clutch would also come out of adjustment regularly, so I also learned how to upshift without using the clutch, and eventually, how to downshift without the clutch, too. I also had to learn how to get it home when the clutch wouldn't declutch at all, which is exciting at stoplights (stall it at the light, put it in gear, release the clutch, and turn the key when the light turns green).
Hey PB, are you old enough to remember rolling clutch starts? Great for sneaking away for whatever reason you might need to sneak away...
